Ga door naar hoofdinhoud
Nerf N-Strike Firestrike Firing Trigger Replacement
Wat je nodig hebt
  1. Nerf N-Strike Firestrike Firing Trigger Replacement, Remove battery cover: stap 1, afbeelding 1 van 1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike Firing Trigger Replacement: stap 2, afbeelding 1 van 2 Nerf N-Strike Firestrike Firing Trigger Replacement: stap 2, afbeelding 2 van 2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike Firing Trigger Replacement, Blaster Casing: stap 3, afbeelding 1 van 1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike Firing Trigger Replacement: stap 4, afbeelding 1 van 2 Nerf N-Strike Firestrike Firing Trigger Replacement: stap 4, afbeelding 2 van 2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike Firing Trigger Replacement: stap 5, afbeelding 1 van 2 Nerf N-Strike Firestrike Firing Trigger Replacement: stap 5, afbeelding 2 van 2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: stap 6, afbeelding 1 van 2 Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: stap 6, afbeelding 2 van 2
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Jong Wan Kim
422 Reputatie
2 handleidingen geschreven
Cal Poly, Team 15-6, Amido Spring 2015 Lid van Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 2,991
