Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lay the Nerf Strongarm on its side, left side facing up.
Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
At this time, remove the blaster cover to reveal its internals.
Once the screws have been removed, lift the top half of the gun off.
Take care and try not to lose any smaller pieces as you open it up.
Locking tab for attachments.
Locate the trigger mechanism's assembly, and notice that it's held in place by a single philip's head screw. Remove it.
Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
Inspect the orange parts for signs of damage and debris. Any broken pieces must be replaced.
This is the spring that controls the trigger. Through regular use, the spring may become mangled or damaged. If it becomes damaged, a spring from a ballpoint pen can function as a decent replacement.
9 andere personen hebben deze handleiding voltooid.
