Ga door naar hoofdinhoud
Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement
Wat je nodig hebt
  1. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement, Outer Shell: stap 1, afbeelding 1 van 2 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement, Outer Shell: stap 1, afbeelding 2 van 2
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 2, afbeelding 1 van 2 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 2, afbeelding 2 van 2
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 3, afbeelding 1 van 1
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 4, afbeelding 1 van 1
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 5, afbeelding 1 van 1
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
    what is a locking tab? and where do i see it? sorry my english is bad
    JoseRafael - Antwoord
    its the front sight post
    Seth Mains - Antwoord
  6. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement, Cocking Mechanisim: stap 6, afbeelding 1 van 2 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement, Cocking Mechanisim: stap 6, afbeelding 2 van 2
    • Remove the screw on the inside of the gun.
    • Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  7. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 7, afbeelding 1 van 2 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 7, afbeelding 2 van 2
    • Remove the barrel from the blaster.
    • Remove the front component from the blaster.
    • Both components do not need any tools to be removed.
  8. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 8, afbeelding 1 van 3 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 8, afbeelding 2 van 3 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 8, afbeelding 3 van 3
    • First, remove the trigger.
    • Then remove the cocking holdback.
    • Then remove the air compressor chamber.
  9. Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 9, afbeelding 1 van 3 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 9, afbeelding 2 van 3 Nerf N-Strike Elite Strongarm Cocking Mechanisim Replacement: stap 9, afbeelding 3 van 3
    • Locate and remove the indicated screw.
    • This is the spring controlling the cocking mechanism. If the spring is damaged, replace it.
    Where do I buy a new one
    The Irish Potato - Antwoord
    I was wondering the same thing
    Whammer52 - Antwoord
    what are screw specifications?
    ATM - Antwoord
    Hi where do I buy that spring?
    Keith tok - Antwoord
    hi my spring is broken to and i was wondering where to buy a replacement spring for this nerf blaster
    Logica Met ons - Antwoord
Conclusie
17 andere personen hebben deze handleiding voltooid.
Chelsea Ebey
423 Reputatie
1 Handleiding geschreven
USF Tampa, Team 5-4, Blackwell Fall 2015 Lid van USF Tampa, Team 5-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G4
4 Leden
12 handleidingen geschreven
20 opmerkingen
That screw holding the spring on the cocking mechanism, I accidently misplaced that, can you tell me what type of screw it is so I could buy a replacement.
Cheers :D
HNK - Antwoord
Where does the locking tab in step 5 go
ryandavidseeweizhi - Antwoord
on the top of the gun(Seeing from the position as if you're aiming)
Its only there for accesory so it still works if you don't return it
chanisco -
butt my spring was not damaged so whats wrong then?
Cryo - Antwoord
The catch piece that catches the trigger slide broke when the kids dropped it while cocked. I tried gorrila gluing the very small platic nubs back on but they couldnt hold the spring pressure when cocked and broke again. Where can i buy parts?
kris_866 - Antwoord
What type of spring is it and where can I buy it because I stretched it too much and now it won't work
Me too, someone please answer this!
Wesley Wurm -
Where did the little, orange rectangle that appears in Step 5 come from and where do I put it back??
Christopher Davis - Antwoord
Ooops, okay, got it. I just saw the message above on this same topic!
Christopher Davis -
thanks for writing this , it helps alot
Ching Lee - Antwoord
Where could I get a replacement for the spring that pulls the cocking mechanism back?
Wesley Wurm - Antwoord
I NEED TO KNOW WHERE TO GET A REPLACEMENT SPRING!!!!!!!!! Plz tell meh
Please any links or information on the replacement springs? You can’t complete this fix without new springs….
Nicole Cochetti - Antwoord
WHAT TYPE OF SCREW
•Locate and remove the indicated screw.
ATM - Antwoord
So I had the same problem I fixed the gun without the return spring. It isn’t worth Jack. I found with a side by side comparison of the disruptor and Strongarm that on the catch the disruptor has a better spring which fits on an internal notch. On the Strongarm you have to compress the catch spring a bit to fit it in.
James 101 - Antwoord
Make sure the catch spring doesn’t clip over or it won’t work.
The piece of plastic that hoocks on to the plunger brock off so I cant find a spare part
What should I do?
ARYA BHATTACHARYA - Antwoord
Where can i buy a replacement spring for the priming handle on a disruptor
Landon martin - Antwoord
mine will slam fire, but not single fire. any tips?
Wookie Warrior - Antwoord
What type of spring and screw do I need?
Adam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 102
Altijd: 27,726
