Ga door naar hoofdinhoud
Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement
Wat je nodig hebt
  1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: stap 1, afbeelding 1 van 2 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: stap 1, afbeelding 2 van 2
    • Remove three screws with a Phillips #1 screwdriver.
    • Remove the pump grip.
  2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 2, afbeelding 1 van 1
    • Remove thirteen highlighted screws using a Phillips #1 screwdriver.
    • The top rail has shorter screws than the rest.
    • Some of these are captive screws and cannot be removed.
  3. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 3, afbeelding 1 van 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 3, afbeelding 2 van 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 3, afbeelding 3 van 3
    • Remove the backside by sliding the plastic spudger across the seam.
    • There are loose parts that can fall out. Take these off and put them aside.
  4. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 4, afbeelding 1 van 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 4, afbeelding 2 van 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 4, afbeelding 3 van 3
    • Separate the trigger mechanism from the barrel.
  5. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 5, afbeelding 1 van 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 5, afbeelding 2 van 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 5, afbeelding 3 van 3
    • Remove the plunger springs from the mechanism by pulling one of the springs back then bending it off the connection.
    • These are tricky to remove, so be careful when pulling them off.
  6. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 6, afbeelding 1 van 2 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: stap 6, afbeelding 2 van 2
    • Now pull the springs out and add new ones.
    • There are a few pieces with springs that can misalign in reassembly. Keep in mind where they are.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 33
Altijd: 3,012
