Inleiding
A displaced or damaged firing spring could render your blaster futile in combat. Periodic replacement as a preventative maintenance strategy may allow you to avoid this unfortunate situation.
Modifying your blaster is not advised and may void the manufacturer’s warranty in certain states.
This blaster is equipped with a rifled barrel for maximum performance.
Wat je nodig hebt
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
Carefully pull the orange trigger upward and backward to remove it from the blaster.
Remove the spring from the rear of the trigger.
Één andere persoon heeft deze handleiding voltooid.
