Inleiding
A fatigued spring can be detrimental to your blaster’s performance. This guide shows how to disassemble the blaster to replace this component. There many small components such as screws and springs that will be removed in this procedure. Be sure to record their locations for easy reassembly.
Wat je nodig hebt
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
While holding down the white Plunger tube, pull the spring backwards to remove it from the blaster.
11 andere personen hebben deze handleiding voltooid.
2 opmerkingen
how do I remove the screws that you have to pull back the sliding mechanism if it cant be pulled back
