Inleiding
Use this guide to remove the circuit board that activates the automatic firing mechanism.
Wat je nodig hebt
Remove the two 9.0 mm Phillips screws securing the battery compartment.
Slide the battery compartment out.
Once you have the handle disassembled locate the triggering circuit board.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
Hi, my Trigger circuit board has a white build up on it.
im not sure if this is a sign of a fried circuit, but my gun won’t rev up. Is there anything I can do?
its located in one of the 6 little metal sauter marks in the middle of it.
