Inleiding
Use this guide to detach the damaged left shell so you'll be able to replace it with an undamaged shell. This guide can also be used with the 5 other Nerf N-Strike Elite Hail-Fire guides to replace other parts.
Wat je nodig hebt
Remove the two 9.0 mm Phillips screws securing the battery compartment.
Slide the battery compartment out.
Één andere persoon heeft deze handleiding voltooid.
