Ga door naar hoofdinhoud
Nerf N-Strike Elite Hail-Fire Battery Replacement
Wat je nodig hebt
  1. Nerf N-Strike Elite Hail-Fire Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the two 9.0 mm Phillips screws from the battery compartment.
  2. Nerf N-Strike Elite Hail-Fire Battery Replacement: stap 2, afbeelding 1 van 1
    • Pull the battery compartment out and away from the gun.
  3. Nerf N-Strike Elite Hail-Fire Battery Replacement: stap 3, afbeelding 1 van 1
    • Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
  4. Nerf N-Strike Elite Hail-Fire Battery Replacement: stap 4, afbeelding 1 van 1
    • Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
  5. Nerf N-Strike Elite Hail-Fire Battery Replacement: stap 5, afbeelding 1 van 1
    • When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Jonathan Peck
217 Reputatie
1 Handleiding geschreven
Cal Poly, Team 13-13, Regan Winter 2014 Lid van Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 Leden
7 handleidingen geschreven
Één opmerking
thanks it works
unturned lore - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 94
Altijd: 25,621
