Ga door naar hoofdinhoud
Nerf Dart Tag Furyfire Large Spring Replacement
Wat je nodig hebt
  1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove the screws: stap 1, afbeelding 1 van 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Panel: stap 2, afbeelding 1 van 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Black Cylinder: stap 3, afbeelding 1 van 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: stap 4, afbeelding 1 van 2 Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: stap 4, afbeelding 2 van 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
Conclusie
Bradley Penrow
37 Reputatie
4 handleidingen geschreven
USF Tampa, Team 11-2, Blackwell Fall 2014 Lid van USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 1,444
