Ga door naar hoofdinhoud
Nerf Alpha Trooper CS-18 Plunger Replacement
Wat je nodig hebt
  1. Nerf Alpha Trooper CS-18 Plunger Replacement, Plunger: stap 1, afbeelding 1 van 1
    • It is important to group screws together by length to ensure proper reassembly.
    • Be sure that the device has been discharged and is unloaded before beginning the repair process.
  2. Nerf Alpha Trooper CS-18 Plunger Replacement: stap 2, afbeelding 1 van 3 Nerf Alpha Trooper CS-18 Plunger Replacement: stap 2, afbeelding 2 van 3 Nerf Alpha Trooper CS-18 Plunger Replacement: stap 2, afbeelding 3 van 3
    • Look at the rear of the rifle. Remove the two 10 mm Phillips head screws that hold the black cap to the rear of the rifle.
    • Gently remove the black cap.
  3. Nerf Alpha Trooper CS-18 Plunger Replacement: stap 3, afbeelding 1 van 2 Nerf Alpha Trooper CS-18 Plunger Replacement: stap 3, afbeelding 2 van 2
    • Point the barrel of the device to the left, screw side up. Remove the two 8 mm Phillips head screws (the top two) holding the device slide together.
    • Keep the device in the same position, remove the three 10 mm Phillips head screws from the bottom of the device slide.
    • Once all screws are removed, carefully separate the two halves of the device slide and put them aside.
    • Be sure to keep track of which screws correspond to the correct holes.
  4. Nerf Alpha Trooper CS-18 Plunger Replacement: stap 4, afbeelding 1 van 3 Nerf Alpha Trooper CS-18 Plunger Replacement: stap 4, afbeelding 2 van 3 Nerf Alpha Trooper CS-18 Plunger Replacement: stap 4, afbeelding 3 van 3
    • Keeping the barrel in the same position as step 3, remove the fourteen 10 mm Phillips head screws from the body of the device.
    • With the device in the same position, remove the 4 remaining 5 mm Phillips head screws from the body of the device.
    • Screws vary in lengths. Be sure to keep track of which screws correspond to the correct holes.
  5. Nerf Alpha Trooper CS-18 Plunger Replacement: stap 5, afbeelding 1 van 3 Nerf Alpha Trooper CS-18 Plunger Replacement: stap 5, afbeelding 2 van 3 Nerf Alpha Trooper CS-18 Plunger Replacement: stap 5, afbeelding 3 van 3
    • Grip the cartridge insert, and pull the two halves of the device apart.
    • Warning! The firing spring is not fastened to the device. It and other small parts may fall out of the device when separating it.
    • If you are having difficulty separating the two halves of the device, use a spudger to pry the two halves apart.
    • Remove the access gate and barrel cover.
  6. Nerf Alpha Trooper CS-18 Plunger Replacement: stap 6, afbeelding 1 van 1
    • Now remove the main firing spring from the rear of the device by gently pulling it.
  7. Nerf Alpha Trooper CS-18 Plunger Replacement: stap 7, afbeelding 1 van 2 Nerf Alpha Trooper CS-18 Plunger Replacement: stap 7, afbeelding 2 van 2
    • Slide the plunger lock back away from the device, then lift out towards yourself to remove.
    • Be careful not to lose the small spring on the top of the plunger lock.
  8. Nerf Alpha Trooper CS-18 Plunger Replacement: stap 8, afbeelding 1 van 1
    • Pull plunger away in the same motion as in step 7 with the plunger lock.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 24
Altijd: 2,183
