Ga door naar hoofdinhoud
Necklace Chain Repair
Wat je nodig hebt
    1. Necklace Chain Repair, Necklace Chain Repair: stap 1, afbeelding 1 van 1
      • Look closely at where the necklace chain came apart. You will see a split ring, otherwise known as a jump ring.
      • Figure A: The jump ring is located on one end of the necklace.
      Vraag FixBot
      Voeg opmerking toe
    2. Necklace Chain Repair: stap 2, afbeelding 1 van 2 Necklace Chain Repair: stap 2, afbeelding 2 van 2
      • Figures B and C: While holding the needle nose pliers in one hand, clamp onto one end of the jump ring and hold on to the other end with your thumb and index finger.
      • Carefully pull on the ends of the jump ring until the opening is large enough to accommodate one of the chain links.
      • Warning: Do not separate the jump ring ends too far apart, otherwise damage to the jump ring may occur.
      Vraag FixBot
      Voeg opmerking toe
    3. Necklace Chain Repair: stap 3, afbeelding 1 van 2 Necklace Chain Repair: stap 3, afbeelding 2 van 2
      • Now that the jump ring opening is separated, you can reattach the chain. Find the end of the chain that had detached from the necklace.
      • Figures D and E: While holding the jump ring in one hand and the end of the necklace in your other hand, proceed to loop the chain into the opened jump ring.
      Vraag FixBot
      Voeg opmerking toe
    4. Necklace Chain Repair: stap 4, afbeelding 1 van 1
      • Figure F: Using similar methods from Step 2 Figure C, clamp onto one end of the jump ring slit with your pliers and hold on to the other end with your thumb and index finger.
      • Carefully close the opening of the jump ring.
      Vraag FixBot
      Voeg opmerking toe
    5. Necklace Chain Repair: stap 5, afbeelding 1 van 2 Necklace Chain Repair: stap 5, afbeelding 2 van 2
      • Figure G: It is time to close the jump ring. With your pliers, clamp on both ends of the jump ring and push together so the two ends of the jump ring slightly overlap.
      • Refer to Figure H for finished assembly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To make sure the necklace is correctly reattached, gently pull on the chain. The jump ring should be firmly closed as to prevent the chain from slipping off the jump ring.
5 andere personen hebben deze handleiding voltooid.
Stephanie Lascola
361 Reputatie
1 Handleiding geschreven
Cal Poly, Team 28-4, Green Spring 2015 Lid van Cal Poly, Team 28-4, Green Spring 2015
CPSU-GREEN-S15S28G4
6 Leden
60 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 124
Altijd: 6,360
