Ga door naar hoofdinhoud
Neato XV-21 Wheels Replacement
Wat je nodig hebt
  1. Neato XV-21 Wheels Replacement, Back Panels of Neato XV-21: stap 1, afbeelding 1 van 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Wheels Replacement: stap 2, afbeelding 1 van 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Wheels Replacement: stap 3, afbeelding 1 van 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Wheels Replacement, Battery: stap 4, afbeelding 1 van 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Wheels Replacement, Wheels: stap 5, afbeelding 1 van 1
    • Pinch and pull the white connector, indicated in the image, to disconnect the wheel from the robot. Repeat for both wheels
  6. Neato XV-21 Wheels Replacement: stap 6, afbeelding 1 van 1
    • Slide out dowel rod connecting the wheel to the robot.
  7. Neato XV-21 Wheels Replacement: stap 7, afbeelding 1 van 2 Neato XV-21 Wheels Replacement: stap 7, afbeelding 2 van 2
    • Lift the wheel so the spring is exposed
    • Pay particular attention to how the wheel is placed to replicate during reinsertion
    • Unhook the spring from robot
    • Lift the wheel from the cavity
Conclusie
3 andere personen hebben deze handleiding voltooid.
Één opmerking
Needs to Link to Parts List and a way to Order Parts.
Bill Price - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 722
