Ga door naar hoofdinhoud
Neato XV-21 Fan Replacement
Wat je nodig hebt
  1. Neato XV-21 Fan Replacement, Back Panels of Neato XV-21: stap 1, afbeelding 1 van 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Fan Replacement: stap 2, afbeelding 1 van 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Fan Replacement: stap 3, afbeelding 1 van 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Fan Replacement, Battery: stap 4, afbeelding 1 van 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Fan Replacement, Fan: stap 5, afbeelding 1 van 2 Neato XV-21 Fan Replacement, Fan: stap 5, afbeelding 2 van 2
    • Pinch the white connectors to disconnect the fan from the robot, as previously done with the batteries
    • Once the wires are disconnected lift the fan from the cavity
  6. Neato XV-21 Fan Replacement: stap 6, afbeelding 1 van 1
    • Once the fan has been removed you can take a damp cloth and clean the cavity before attaching the new device
Conclusie
3 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,134
