Ga door naar hoofdinhoud
Neato Botvac 80 Top Face Panel Replacement
Wat je nodig hebt
  1. Neato Botvac 80 Top Face Panel Replacement, Rear Bumper: stap 1, afbeelding 1 van 1
    • Grab the rear bumper with both hands on either side.
  2. Neato Botvac 80 Top Face Panel Replacement: stap 2, afbeelding 1 van 1
    • Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
  3. Neato Botvac 80 Top Face Panel Replacement, Top Face Panel: stap 3, afbeelding 1 van 2 Neato Botvac 80 Top Face Panel Replacement, Top Face Panel: stap 3, afbeelding 2 van 2
    • Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
  4. Neato Botvac 80 Top Face Panel Replacement: stap 4, afbeelding 1 van 1
    • Begin by placing the robot on it's back and removing the six 11m screws using a Torx T10 screwdriver.
  5. Neato Botvac 80 Top Face Panel Replacement: stap 5, afbeelding 1 van 3 Neato Botvac 80 Top Face Panel Replacement: stap 5, afbeelding 2 van 3 Neato Botvac 80 Top Face Panel Replacement: stap 5, afbeelding 3 van 3
    • To remove the top, you must press in both of the clamps at the same time and push upwards.
    • When removing the top, before you can completely take it off you must unplug the LCD power cable from the motherboard.
Conclusie
Brandon Blank
675 Reputatie
5 handleidingen geschreven
USF Tampa, Team 17-5, Blackwell Spring 2017 Lid van USF Tampa, Team 17-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G5
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 941
