Inleiding
This guide will show you how to replace a faulty laser.
Wat je nodig hebt
Pull the left and right sides away from the machine to unclip the bumper. This requires that you bend the plastic a little bit. Unclip one side a little bit and allow the prong to rest on the side of the machine. Then unclip the other side and pull off the bumper parallel to both sides
Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
Lift gently upon the top panel.
Unplug the clip located on the right side before completely removing.
4 andere personen hebben deze handleiding voltooid.
9 opmerkingen
lol. You don’t need to open it to replace the laser. The top is a clip on. Just pull it and remove 4 screws.
where do you buy the replacement laser?
I too would like to know where he got a replacement laser.
where do I buy a replacement laser?
bjurgensen79@gmail.com
Beverly Jurgensen
Where do I buy a replacement laser?
Beverly Jurgensen
