Ga door naar hoofdinhoud
Neato Botvac 80 Brush Replacement
Wat je nodig hebt
  1. Neato Botvac 80 Brush Replacement, Remove Small Wheels: stap 1, afbeelding 1 van 2 Neato Botvac 80 Brush Replacement, Remove Small Wheels: stap 1, afbeelding 2 van 2
    • Note: This step is not necessaryto remove the brush guard. Only do this is the wheels are not spinning correctly To begin, turn the Neato Botvac 80 upside down and locate the brush. Remove the 4 screws highlighted in red, and remove the cover. This releases the 2 small wheels, where you can remove the hair that gets tangled in them.
    • You will need to remove the four 10mm bolts with a T10 Torx screwdriver.
  2. Neato Botvac 80 Brush Replacement: stap 2, afbeelding 1 van 1
    • Find the two inlays in front of the wheels and pull them to release the brush guard.
  3. Neato Botvac 80 Brush Replacement, Remove Brush: stap 3, afbeelding 1 van 1
    • Remove brush by pulling out and to the side.
    • If you want to replace: repeat these steps in reverse with the new brush bar
    • If you want to clean: take the metal bearing off the side, remove the hair wrapped in the orange holder. With a scissors, cut the hair out of the brush roll. Re-insert the brushroll and re-install the brush guard
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Brandon Blank
675 Reputatie
5 handleidingen geschreven
USF Tampa, Team 17-5, Blackwell Spring 2017 Lid van USF Tampa, Team 17-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G5
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 2,475
