Ga door naar hoofdinhoud
Neato Botvac 65 Top Cover Removal
Wat je nodig hebt
  1. Neato Botvac 65 Top Cover Removal, Battery: stap 1, afbeelding 1 van 2 Neato Botvac 65 Top Cover Removal, Battery: stap 1, afbeelding 2 van 2
    • Flip the device upside down.
    • Locate the two (2) 20mm screws on the batttery plate.
  2. Neato Botvac 65 Top Cover Removal: stap 2, afbeelding 1 van 2 Neato Botvac 65 Top Cover Removal: stap 2, afbeelding 2 van 2
    • Use the Phillips #1 screwdriver to loosen both screws.
  3. Neato Botvac 65 Top Cover Removal: stap 3, afbeelding 1 van 1
    • Remove the battery back plate to reveal the battery.
  4. Neato Botvac 65 Top Cover Removal: stap 4, afbeelding 1 van 2 Neato Botvac 65 Top Cover Removal: stap 4, afbeelding 2 van 2
    • Disconnect the current battery by pulling the connector from the base and pushing on the clip.
  5. Neato Botvac 65 Top Cover Removal, Brush: stap 5, afbeelding 1 van 1
  6. Neato Botvac 65 Top Cover Removal: stap 6, afbeelding 1 van 2 Neato Botvac 65 Top Cover Removal: stap 6, afbeelding 2 van 2
    • Use the screwdriver to take off the four (4) 10mm screws located near the brush which secure the plastic guard.
  7. Neato Botvac 65 Top Cover Removal: stap 7, afbeelding 1 van 2 Neato Botvac 65 Top Cover Removal: stap 7, afbeelding 2 van 2
    • Remove the plastic brush guard.
    • Pull off the plastic covering the brush.
  8. Neato Botvac 65 Top Cover Removal: stap 8, afbeelding 1 van 1
    • Lift the brush to clean or replace.
  9. Neato Botvac 65 Top Cover Removal, Top Cover: stap 9, afbeelding 1 van 1
    • Flip device upside down.
    • Locate the six (6) screw connected to the top cover.
  10. Neato Botvac 65 Top Cover Removal: stap 10, afbeelding 1 van 1
    • Remove eight (8) star screws using the T10 bit.
  11. Neato Botvac 65 Top Cover Removal: stap 11, afbeelding 1 van 2 Neato Botvac 65 Top Cover Removal: stap 11, afbeelding 2 van 2
    • Pull off one side of the brush front cover, and then pull off the other.
  12. Neato Botvac 65 Top Cover Removal: stap 12, afbeelding 1 van 1
    • Flip right side up and turn around.
    • FInd the two clips connecting the top cover to the body of the device.
  13. Neato Botvac 65 Top Cover Removal: stap 13, afbeelding 1 van 2 Neato Botvac 65 Top Cover Removal: stap 13, afbeelding 2 van 2
    • Lift up on the top cover gently.
    • Disconnect the connector from the motherboard to detach the top cover from the robot.
Conclusie
Joseph Caton
334 Reputatie
3 handleidingen geschreven
USF Tampa, Team S2-G1, Lacy Spring 2017 Lid van USF Tampa, Team S2-G1, Lacy Spring 2017
USFT-LACY-S17S2G1
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 1,282
