Inleiding
If the main brush on your device stops working correctly, it may need to be replaced.
Wat je nodig hebt
Turn the Neato Botvac upside down so the brushes and wheels are facing upward.
Pop the tabs shown on the main brush cover, and then pull. It should come right off. You can put it aside for now.
Pull down the latch under the sensor and then carefully remove it from the unit.
Bijna klaar!
Conclusie
