Inleiding
In this guide you will be able to replace the side wheel of the Neato Botvac Connected. This wheel will need to be replaced if it is not moving the vacuum properly. The wheel will also need to be replaced if the vacuum decides to stop moving at all. Using this guide comes after having to remove the battery as a precaution.
Wat je nodig hebt
Remove the following screws with a Torx screwdriver:
Four 2.3 mm screws.
Remove the following screws with a TR10 Torx screwdriver:
Six 2.3 mm screws.
Één andere persoon heeft deze handleiding voltooid.
