Inleiding
In this guide you will be able to replace the front roller of the Neato Botvac Connected. This will need to be replaced if there is excessive noise coming from the vacuum or if there are excess debris. In order to complete this guide you must first follow the guide to disconnect the battery.
Wat je nodig hebt
Remove the following screws with a Torx screwdriver:
Four 2.3 mm screws.
Bijna klaar!
Conclusie
