Ga door naar hoofdinhoud
Inleiding
Have you ever brought nail clippers on a trip, only to find that they had fallen apart in your bag. Before buying a new pair, try fixing them with this simple guide. As long as you have all three necessary parts, if you follow these easy steps your nail clippers will be as good as new.
  1. Nail Clipper Reassembly, Nail Clipper Reassembly: stap 1, afbeelding 1 van 3 Nail Clipper Reassembly, Nail Clipper Reassembly: stap 1, afbeelding 2 van 3 Nail Clipper Reassembly, Nail Clipper Reassembly: stap 1, afbeelding 3 van 3
    • Insert the rod through the bottom hole of the clipper body, and continue through the top hole.
    • The side of the rod with the notch should be inserted first.
    • Note: The top of the clipper body will often have a pick/file attached to it. If no pick/file is present, either side can serve as the top or the bottom.
  2. Nail Clipper Reassembly: stap 2, afbeelding 1 van 1
    • Compress the body of the clippers to reveal the notch.
    It is really hard for me to do this with one hand. help?
    Ashleberry - Antwoord
  3. Nail Clipper Reassembly: stap 3, afbeelding 1 van 1
    • Rotate the rod until the notch opening faces away from the body.
    • This allows for easier completion of the following step.
  4. Nail Clipper Reassembly: stap 4, afbeelding 1 van 3 Nail Clipper Reassembly: stap 4, afbeelding 2 van 3 Nail Clipper Reassembly: stap 4, afbeelding 3 van 3
    • Place the hole of the lever into the revealed rod notch.
    • Release the compressed nail clipper body to lock the lever into place.
    • Note: Position of the lever does not matter at this point.
  5. Nail Clipper Reassembly: stap 5, afbeelding 1 van 3 Nail Clipper Reassembly: stap 5, afbeelding 2 van 3 Nail Clipper Reassembly: stap 5, afbeelding 3 van 3
    • Swivel the lever into its normal position, and test the nail clippers' functionality.
    I accidentally broke my grandma’s nail clipper
    but I fixed cuz of dis
    NATALIE GARZA - Antwoord
Conclusie
If you follow these steps, your nail clippers should be back to working order.
55 andere personen hebben deze handleiding voltooid.
Robert Weber
1.643 Reputatie
1 Handleiding geschreven
Cal Poly, Team 30-5, Green Spring 2015 Lid van Cal Poly, Team 30-5, Green Spring 2015
CPSU-GREEN-S15S30G5
5 Leden
30 handleidingen geschreven
13 Opmerkingen
Thank you so much ! My fingers are arthritic and I was frustrated until I found your instructions.
marvin - Antwoord
Thank you. Knew it was simple! Love this website.
jonathanl.aguiar - Antwoord
This is the dumbest “repair guide” I have ever seen. It is not a repair, because they are not broken, it’s a re-assembly.
Albert E - Antwoord
That's why it says reassembly 🤨
Blake Jordan-Borns -
Thank you so much!!!! I could only find one pair in my house and was feeling desperate. This is the best guide to repair and I’m glad you posted under broken nail clippers because that’s what I considered mine to be and how I looked it up.
Tanya Bishop - Antwoord
I used you steps, but whenever I try to rotate the handle so that I can clip my nails the handle just pops off again.
Arianna Gessaman - Antwoord
Albert E, the name of the website is “Nail Clipper Reassembly” you are not prooving a point. Its not dumb either because everyone else’s nail clippers work now. And the deffintion of repair is…
re·pair1
/rəˈper/
verb
1.
fix or mend (a thing suffering from damage or a fault). Or put something back together.
"faulty electrical appliances should be repaired by an electrician"
synonyms:mend, fix (up), put right, set right, restore, restore to working order, make as good as new, patch up, overhaul, service, renovate, recondition, rehabilitate, rebuild, reconstruct, refit, adjust, regulate; More
noun
Thank you!! I have been trying for weeks! Your pictures are awesome. I looked at the 1st one and I was good to go!
G Coker - Antwoord
where would you find a replacement pin? Mine is bent beyond repair. mymothersblessing@yahoo.com.
mymothersblessing - Antwoord
its good idk what else to say
Jaden Carter - Antwoord
Perfect instructions!
Janine C Kniola - Antwoord
Came home drunkk; stepped on my toenaiil clippers; googled how do I fix my toenail clippers; found your tutorial, and I fixed them!!!
I may not remember this tomorrow, but your tutorial was great. Thank you
KIMBER FLETCHER - Antwoord
Thank you so much, this really helped!
Sophie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 69
Afgelopen 7 dagen: 506
Afgelopen 30 dagen: 2,120
Altijd: 68,683
