Ga door naar hoofdinhoud
Nabi Jr Speakers Replacement
Wat je nodig hebt
  1. Nabi Jr Speakers Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Speakers Replacement: stap 2, afbeelding 1 van 1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Speakers Replacement: stap 3, afbeelding 1 van 1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Speakers Replacement: stap 4, afbeelding 1 van 1
    • After loosening the back cover, remove it from the device so you can get at the innards.
  5. Nabi Jr Speakers Replacement, Speakers: stap 5, afbeelding 1 van 1
    • The speakers are located near the top of the device close to the camera.
    • Using a desoldering tool, remove the speakers from the pads they are soldered to.
    • Note that the red wire is removed from the pad labeled with a "+" and the black wire comes from the pad labeled with a "-".
    • Solder the new speaker's wires onto their respective pads
Conclusie
Tobias Young
27 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 Lid van UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 849
