Ga door naar hoofdinhoud
Nabi Jr Rear Case Replacement
Wat je nodig hebt
  1. Nabi Jr Rear Case Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Remove the red rubber case from the device. This should come off with ease.
  2. Nabi Jr Rear Case Replacement: stap 2, afbeelding 1 van 1
    • Turn the device so the screen is facing away from you.
    • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
  3. Nabi Jr Rear Case Replacement: stap 3, afbeelding 1 van 1
    • Remove the device casing using a small plastic pry bar.
    • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
  4. Nabi Jr Rear Case Replacement: stap 4, afbeelding 1 van 1
    • After loosening the back cover, remove it from the device so you can get at the innards.
Conclusie
Tobias Young
27 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 Lid van UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 388
