Ga door naar hoofdinhoud
Nabi DreamTab HD8 Battery Replacement
Wat je nodig hebt
  1. Nabi DreamTab HD8 Battery Replacement, Front Panel Assembly: stap 1, afbeelding 1 van 2 Nabi DreamTab HD8 Battery Replacement, Front Panel Assembly: stap 1, afbeelding 2 van 2
    • Position the Nabi DreamTab onto a non-metallic surface so that the screen is facing towards the ceiling, and the DreamTab logo appears closest to you.
    • Remove the red silicone case from the Nabi DreamTab HD8.
    • These steps are specific to the included manufacturer case. If you have a different protective case, please refer to the respective manual for removal.
  2. Nabi DreamTab HD8 Battery Replacement: stap 2, afbeelding 1 van 1
    • Turn it upside down, ensuring the small black circular camera is in the upper left hand corner.
    • Proceeding beyond here will void the manufacturer's warranty. If you wish to continue, follow these steps carefully.
  3. Nabi DreamTab HD8 Battery Replacement: stap 3, afbeelding 1 van 2 Nabi DreamTab HD8 Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the six 2.5 mm JIS #000 screws attaching the custom grid to the back panel.
  4. Nabi DreamTab HD8 Battery Replacement: stap 4, afbeelding 1 van 2 Nabi DreamTab HD8 Battery Replacement: stap 4, afbeelding 2 van 2
    • Grasp one of the protruding squares and gently lift off the back plate. Place it aside for later reassembly.
    • This piece should come off very easily. If you have trouble removing it, all of the screws may not be completely removed. Check and proceed.
    • Do not confuse the golden threads for screws.
  5. Nabi DreamTab HD8 Battery Replacement: stap 5, afbeelding 1 van 3 Nabi DreamTab HD8 Battery Replacement: stap 5, afbeelding 2 van 3 Nabi DreamTab HD8 Battery Replacement: stap 5, afbeelding 3 van 3
    • Remove the three 3.5mm screws using the J-0 screwdriver attaching the back panel to the device.
  6. Nabi DreamTab HD8 Battery Replacement: stap 6, afbeelding 1 van 3 Nabi DreamTab HD8 Battery Replacement: stap 6, afbeelding 2 van 3 Nabi DreamTab HD8 Battery Replacement: stap 6, afbeelding 3 van 3
    • Rotate the top of the device towards you so that the audio jack appears on the right side of the device.
    • The audio jack will have a small symbol of headphones next to a small 3.5mm diameter hole.
    • Wedge the plastic opening tool between where the front and back case panels meet near the audio jack.
    • Pry the device open using moderate force until you hear a clicking sound. This is the sound of the clips unlocking.
    • Move along the perimeter of the entire device using the same prying motion to gradually separate the front and back panels.
    • Once the edges are open return to the same starting position next to the audio jack.
    • During this step, you may crack some parts of the case. Gently pry around the speakers, audio jack and charging cable ports to reduce this damage.
  7. Nabi DreamTab HD8 Battery Replacement: stap 7, afbeelding 1 van 3 Nabi DreamTab HD8 Battery Replacement: stap 7, afbeelding 2 van 3 Nabi DreamTab HD8 Battery Replacement: stap 7, afbeelding 3 van 3
    • Once you've completed separating the front and back panels, place the device back onto the table, display facing downward and camera at the top left.
    • Lift off the back panel and rotate the device 180 degrees while the screen is facing down.
  8. Nabi DreamTab HD8 Battery Replacement, Battery: stap 8, afbeelding 1 van 1
    • Before removing the battery, be aware that it is held together by a strong adhesive. The battery itself is very malleable and flimsy, so make sure to handle it with care.
  9. Nabi DreamTab HD8 Battery Replacement: stap 9, afbeelding 1 van 3 Nabi DreamTab HD8 Battery Replacement: stap 9, afbeelding 2 van 3 Nabi DreamTab HD8 Battery Replacement: stap 9, afbeelding 3 van 3
    • Remove the remaining yellow plastic film from the surrounding connectors so that the battery can be easily removed.
  10. Nabi DreamTab HD8 Battery Replacement: stap 10, afbeelding 1 van 3 Nabi DreamTab HD8 Battery Replacement: stap 10, afbeelding 2 van 3 Nabi DreamTab HD8 Battery Replacement: stap 10, afbeelding 3 van 3
    • Disconnect the two plastic connectors overlapping the battery from the motherboard.
  11. Nabi DreamTab HD8 Battery Replacement: stap 11, afbeelding 1 van 2 Nabi DreamTab HD8 Battery Replacement: stap 11, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Plastic Cards
    $2.99
    Koop
    • These images show the use of a metal spudger. Use a plastic card or opening pick to avoid puncturing the battery.
    • Slide a plastic card or opening pick between the battery and case. Gently pry the battery out of the case.
  12. Nabi DreamTab HD8 Battery Replacement: stap 12, afbeelding 1 van 3 Nabi DreamTab HD8 Battery Replacement: stap 12, afbeelding 2 van 3 Nabi DreamTab HD8 Battery Replacement: stap 12, afbeelding 3 van 3
    • Disconnect the final battery connector from the motherboard.
    • Remove the battery.
Conclusie
Luis Delgado
263 Reputatie
2 handleidingen geschreven
CSU Fullerton, Team 2-3, Bruce Fall 2015 Lid van CSU Fullerton, Team 2-3, Bruce Fall 2015
CSUF-BRUCE-F15S2G3
4 Leden
10 handleidingen geschreven
8 opmerkingen
Great directions. Good to know stuff. Where, if I may ask, did you find the replacement battery. Thanks in advance, and, keep on keeping on.
Jim Osburn - Antwoord
The inside of my DreamTab looks NOTHING like this. For one, the battery is NOT foil wrapped. Other than that, still nothing like your pictures.
Amy Lathrop - Antwoord
There are two different DreamTab models: DMTAB-IN08A and DMTAB-NV08B.
This procedure is using the DMTAB-NV08B.
Adam Bright -
Restaure mi nabi dream 8 pero ahora no puedo acceder a mi correo me dice , comprobando disponibilidad y no pasa de ahi
Agustin Zapata Martinez - Antwoord
Your guide along with time and patience brought my DT back to life. Thank you sooo much.
laylo2769 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 7,858
