Ga door naar hoofdinhoud
Nabi 2S Speakers Replacement
Wat je nodig hebt
  1. Nabi 2S Speakers Replacement, Nabi 2S Disassembly: stap 1, afbeelding 1 van 1
    • Remove the red rubber case from the device.
  2. Nabi 2S Speakers Replacement: stap 2, afbeelding 1 van 2 Nabi 2S Speakers Replacement: stap 2, afbeelding 2 van 2
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Speakers Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Speakers Replacement: stap 4, afbeelding 1 van 1
    • After the back case is loosened, remove it from the device to change or access the battery.
  5. Nabi 2S Speakers Replacement, Speakers: stap 5, afbeelding 1 van 2 Nabi 2S Speakers Replacement, Speakers: stap 5, afbeelding 2 van 2
    • Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the 4mm screws in a clockwise rotation.
  6. Nabi 2S Speakers Replacement: stap 6, afbeelding 1 van 2 Nabi 2S Speakers Replacement: stap 6, afbeelding 2 van 2
    • The speakers are attached to the device via wires that are connected to a circuit. Grasp the circuit connected to the right speaker.
    • Slide the connected wires from the circuit to detach the speakers.
  7. Nabi 2S Speakers Replacement: stap 7, afbeelding 1 van 3 Nabi 2S Speakers Replacement: stap 7, afbeelding 2 van 3 Nabi 2S Speakers Replacement: stap 7, afbeelding 3 van 3
    • Lift the circuit board to get better access for removing the speaker.
    • Grasp the speaker with your fingers and lift it from the plastic
  8. Nabi 2S Speakers Replacement: stap 8, afbeelding 1 van 2 Nabi 2S Speakers Replacement: stap 8, afbeelding 2 van 2
    • Repeat steps 6 and 7 for the second speaker on the left side.
    • The circuit board should still be loose to remove the speaker.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Riana Ramirez
680 Reputatie
4 handleidingen geschreven
Marist, Team 1-4, Laflen Spring 2016 Lid van Marist, Team 1-4, Laflen Spring 2016
MARS-LAFLEN-S16S1G4
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 9
Altijd: 250
