Ga door naar hoofdinhoud
Nabi 2S Battery Replacement
Wat je nodig hebt
  1. Nabi 2S Battery Replacement, Nabi 2S Disassembly: stap 1, afbeelding 1 van 1
    • Remove the red rubber case from the device.
  2. Nabi 2S Battery Replacement: stap 2, afbeelding 1 van 2 Nabi 2S Battery Replacement: stap 2, afbeelding 2 van 2
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Battery Replacement: stap 3, afbeelding 1 van 1
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Battery Replacement: stap 4, afbeelding 1 van 1
    • After the back case is loosened, remove it from the device to change or access the battery.
  5. Nabi 2S Battery Replacement, Battery: stap 5, afbeelding 1 van 3 Nabi 2S Battery Replacement, Battery: stap 5, afbeelding 2 van 3 Nabi 2S Battery Replacement, Battery: stap 5, afbeelding 3 van 3
    • Grasp the circuit connected to the battery via wires.
    • Slide the wires from the circuit to detach it.
  6. Nabi 2S Battery Replacement: stap 6, afbeelding 1 van 2 Nabi 2S Battery Replacement: stap 6, afbeelding 2 van 2
    • After the circuit is detached, the battery will be easily removable.
    • Don’t rip the battery off of the board.
    • The battery is stuck with adhesive tape to the board.
    • Use a plastic opening tool to apply pressure to the battery and lift it up from the adhesive.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Riana Ramirez
680 Reputatie
4 handleidingen geschreven
Marist, Team 1-4, Laflen Spring 2016 Lid van Marist, Team 1-4, Laflen Spring 2016
MARS-LAFLEN-S16S1G4
2 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 13
Altijd: 780
