Ga door naar hoofdinhoud
Nabi 2 Internal Speakers Replacement
Wat je nodig hebt
  1. Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: stap 1, afbeelding 1 van 3 Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: stap 1, afbeelding 2 van 3 Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: stap 1, afbeelding 3 van 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Internal Speakers Replacement: stap 2, afbeelding 1 van 2 Nabi 2 Internal Speakers Replacement: stap 2, afbeelding 2 van 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Internal Speakers Replacement: stap 3, afbeelding 1 van 3 Nabi 2 Internal Speakers Replacement: stap 3, afbeelding 2 van 3 Nabi 2 Internal Speakers Replacement: stap 3, afbeelding 3 van 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Internal Speakers Replacement, Internal Speakers: stap 4, afbeelding 1 van 1
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  5. Nabi 2 Internal Speakers Replacement: stap 5, afbeelding 1 van 3 Nabi 2 Internal Speakers Replacement: stap 5, afbeelding 2 van 3 Nabi 2 Internal Speakers Replacement: stap 5, afbeelding 3 van 3
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  6. Nabi 2 Internal Speakers Replacement: stap 6, afbeelding 1 van 1
    • Once the screws have been removed, remove the speakers from the device.
Conclusie
Michelle
851 Reputatie
4 handleidingen geschreven
USF Tampa, Team 4-3, Lacy Spring 2016 Lid van USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 719
