Ga door naar hoofdinhoud
Nabi 2 Charging Port Replacement
Wat je nodig hebt
  1. Nabi 2 Charging Port Replacement, Nabi 2 Back Cover Removal: stap 1, afbeelding 1 van 3 Nabi 2 Charging Port Replacement, Nabi 2 Back Cover Removal: stap 1, afbeelding 2 van 3 Nabi 2 Charging Port Replacement, Nabi 2 Back Cover Removal: stap 1, afbeelding 3 van 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Charging Port Replacement: stap 2, afbeelding 1 van 2 Nabi 2 Charging Port Replacement: stap 2, afbeelding 2 van 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Charging Port Replacement: stap 3, afbeelding 1 van 3 Nabi 2 Charging Port Replacement: stap 3, afbeelding 2 van 3 Nabi 2 Charging Port Replacement: stap 3, afbeelding 3 van 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Charging Port Replacement, Screen: stap 4, afbeelding 1 van 3 Nabi 2 Charging Port Replacement, Screen: stap 4, afbeelding 2 van 3 Nabi 2 Charging Port Replacement, Screen: stap 4, afbeelding 3 van 3
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2 Charging Port Replacement: stap 5, afbeelding 1 van 3 Nabi 2 Charging Port Replacement: stap 5, afbeelding 2 van 3 Nabi 2 Charging Port Replacement: stap 5, afbeelding 3 van 3
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
  6. Nabi 2 Charging Port Replacement, Battery: stap 6, afbeelding 1 van 3 Nabi 2 Charging Port Replacement, Battery: stap 6, afbeelding 2 van 3 Nabi 2 Charging Port Replacement, Battery: stap 6, afbeelding 3 van 3
    • Use the spudger to pop the battery out of place and set it aside.
  7. Nabi 2 Charging Port Replacement: stap 7, afbeelding 1 van 3 Nabi 2 Charging Port Replacement: stap 7, afbeelding 2 van 3 Nabi 2 Charging Port Replacement: stap 7, afbeelding 3 van 3
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
  8. Nabi 2 Charging Port Replacement, Internal Speakers: stap 8, afbeelding 1 van 1
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  9. Nabi 2 Charging Port Replacement: stap 9, afbeelding 1 van 3 Nabi 2 Charging Port Replacement: stap 9, afbeelding 2 van 3 Nabi 2 Charging Port Replacement: stap 9, afbeelding 3 van 3
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  10. Nabi 2 Charging Port Replacement: stap 10, afbeelding 1 van 1
    • Once the screws have been removed, remove the speakers from the device.
  11. Nabi 2 Charging Port Replacement, Motherboard: stap 11, afbeelding 1 van 2 Nabi 2 Charging Port Replacement, Motherboard: stap 11, afbeelding 2 van 2
    • Remove the seven 4 mm Phillips #000 screws with a PH#000 screwdriver
  12. Nabi 2 Charging Port Replacement: stap 12, afbeelding 1 van 3 Nabi 2 Charging Port Replacement: stap 12, afbeelding 2 van 3 Nabi 2 Charging Port Replacement: stap 12, afbeelding 3 van 3
    • Remove the tape that is attaching the motherboard to the plastic casing
  13. Nabi 2 Charging Port Replacement: stap 13, afbeelding 1 van 3 Nabi 2 Charging Port Replacement: stap 13, afbeelding 2 van 3 Nabi 2 Charging Port Replacement: stap 13, afbeelding 3 van 3
    • Remove the motherboard by lifting from the area indicated
  14. Nabi 2 Charging Port Replacement, Charging Port: stap 14, afbeelding 1 van 3 Nabi 2 Charging Port Replacement, Charging Port: stap 14, afbeelding 2 van 3 Nabi 2 Charging Port Replacement, Charging Port: stap 14, afbeelding 3 van 3
    • Using a soldering iron, desolder the charging port from the motherboard
    • Remove the charging port completely
    • If the glue does not completely detach from the board, try to heat it until the charging port can be removed
Conclusie
Trevor Westergard
201 Reputatie
1 Handleiding geschreven
USF Tampa, Team 4-3, Lacy Spring 2016 Lid van USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Leden
14 handleidingen geschreven
7 opmerkingen
I think you would be better to just through it away and get something else.
Brad Cobb - Antwoord
Naw they are still a handy fairly tough tablet for the kids shame about badly designed dc port I managed to find ports for it on ebay.
http://www.ebay.com/itm/dc-socket-port-j...
DotDotCom - Antwoord
send me a new nabi in the mail today
Deborah Cramer - Antwoord
A lot of unneeded work there. The power port is surface mount and and can be replaced without removing the PCB or anything else, but the back.
Donnie
Donnie - Antwoord
Do steps 1-3 above then 4 desolder power port and clean area then reverse order.
Donnie
Donnie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 6,391
