Ga door naar hoofdinhoud
NVIDIA GeForce GTX 970 GPU Replacement
Wat je nodig hebt
  1. NVIDIA GeForce GTX 970 GPU Replacement, GPU: stap 1, afbeelding 1 van 2 NVIDIA GeForce GTX 970 GPU Replacement, GPU: stap 1, afbeelding 2 van 2
    • Unplug all the external cables from the computer and ensure that the power supply is switched off.
  2. NVIDIA GeForce GTX 970 GPU Replacement: stap 2, afbeelding 1 van 2 NVIDIA GeForce GTX 970 GPU Replacement: stap 2, afbeelding 2 van 2
    • Remove the case side panel by applying pressure to the side and sliding the side panel toward the back of the case.
    • Some cases may have screws that must be removed or tabs that must be pressed before the siding will slide off.
  3. NVIDIA GeForce GTX 970 GPU Replacement: stap 3, afbeelding 1 van 3 NVIDIA GeForce GTX 970 GPU Replacement: stap 3, afbeelding 2 van 3 NVIDIA GeForce GTX 970 GPU Replacement: stap 3, afbeelding 3 van 3
    • Pinch the lock at the end of the GPU power cable and carefully disconnect it.
  4. NVIDIA GeForce GTX 970 GPU Replacement: stap 4, afbeelding 1 van 3 NVIDIA GeForce GTX 970 GPU Replacement: stap 4, afbeelding 2 van 3 NVIDIA GeForce GTX 970 GPU Replacement: stap 4, afbeelding 3 van 3
    • Remove the two Philips #1 mounting screws that attach the GPU to the inside of the case.
  5. NVIDIA GeForce GTX 970 GPU Replacement: stap 5, afbeelding 1 van 3 NVIDIA GeForce GTX 970 GPU Replacement: stap 5, afbeelding 2 van 3 NVIDIA GeForce GTX 970 GPU Replacement: stap 5, afbeelding 3 van 3
    • Press down the locking tab at the base of the GPU.
  6. NVIDIA GeForce GTX 970 GPU Replacement: stap 6, afbeelding 1 van 1
    • Remove the GPU from the case. If it does not move, check to make sure that steps 3-5 were properly performed.
  7. NVIDIA GeForce GTX 970 GPU Replacement: stap 7, afbeelding 1 van 2 NVIDIA GeForce GTX 970 GPU Replacement: stap 7, afbeelding 2 van 2
    • When inserting a replacement GPU, ensure that the base is lined up properly with the appropriate slot on the motherboard.
    • Once the replacement GPU is lined up, press down until you hear a click or can see that the locking tab is flipped up again.
Conclusie
To finish reassembly, follow steps 2-4 in reverse order.
11 andere personen hebben deze handleiding voltooid.
Nicholas Eichman
415 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 146
Altijd: 7,614
