Ga door naar hoofdinhoud
NERF Doomlands 2169 Lawbringer Blaster Catch Spring Replacement
Wat je nodig hebt
  1. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement, Catch Spring: stap 1, afbeelding 1 van 2 NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement, Catch Spring: stap 1, afbeelding 2 van 2
    • Locate and remove all 14 screws of the outer case and gently remove it avoiding any damage.
  2. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 2, afbeelding 1 van 1
    • Remove the three screws attached to the trigger mechanism of the gun.
    • Be careful when removing the rotating cartridge from the case, as the fulcrum attaching it to the trigger mechanism will fall out.
  3. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 3, afbeelding 1 van 1
    • Remove the exterior spring from the sliding mechanism and re-position the gun on its opposite side.
  4. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 4, afbeelding 1 van 1
    • Remove the three screws holding the trigger plate in place, then remove the plate carefully.
  5. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 5, afbeelding 1 van 1
    • Remove the spring and trigger mechanism from the gun, and set aside.
  6. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 6, afbeelding 1 van 1
    • This is where the spring load mechanism is located, be cautious not to damage. If the spring separates from the gun, reattach it using a screwdriver end.
    • Carefully slide out the big spring and fit in your replacement (thin-coil end coiled around the orange plastic)
  7. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 7, afbeelding 1 van 1
    • A second set of hands would be useful during this step. Make sure the orange slide is above the spring.
    • Keep tension on the spring and begin sliding the new coil spring into the trigger mechanism.
  8. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 8, afbeelding 1 van 1
    • Reconnect the spring to the orange slider, and connect the orange slider to the grey hook.
  9. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 9, afbeelding 1 van 2 NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 9, afbeelding 2 van 2
    • Slide the orange supporting piece into the crevice below the air chamber.
    • Slide the rotating cartridge back into place
  10. NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 10, afbeelding 1 van 2 NERF Doomlands 2169 Lawbringer Blaster Catch Spring  Replacement: stap 10, afbeelding 2 van 2
    • Look to the beginning of this guide for help to reassemble this gun.
    • Carefully reassemble the Nerf Law bringer in the same order you took it apart. Carefully reattach the 3 screws that seal the air chamber.
    • Reattach the other plastic half of the gun. Tighten the screws and you're done.
Conclusie
Daniel Perriello
134 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 1,913
