Inleiding
If the speakers not working, or they are only making a static noise, then replacing them will fix the sound of the NABI XD.
Wat je nodig hebt
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
Right (R) speaker removal:
Remove one 4mm Phillips screw.
Use the metal spudger to separate the speaker from the frame.
