Inleiding
Is the screen cracked or non responsive then replacing it will fix the NABI XD.
Wat je nodig hebt
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
Right (R) speaker removal:
Remove one 4mm Phillips screw.
Use the metal spudger to separate the speaker from the frame.
The ribbons are glued to the frame so gently lift them up without ripping them.
Lightly lift the marked wires and ribbons from the frame by gently pulling them in the direction of the arrows and up.
Remove five 4mm Phillips screws from the frame.
Één andere persoon heeft deze handleiding voltooid.
