Inleiding
Is your charging port damaged, can't charge your device no matter what you have tried. Replacing the charging port may fix those problems.
Wat je nodig hebt
Use the plastic opening tool at the top left corner seam, then pry the corner apart.
Place your fingernails on both sides of the connector and pull it straight back away from the holder.
Bijna klaar!
Conclusie
