Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Gereedschap
Geen gereedschap opgegeven.
  1. Remove the two screws that keep the keyboard together.
    • Remove the two screws that keep the keyboard together.
  2. With a solid and thin object, unclipse the keyboard by pushing it through the holes you have unscrewed previously. With a solid and thin object, unclipse the keyboard by pushing it through the holes you have unscrewed previously. With a solid and thin object, unclipse the keyboard by pushing it through the holes you have unscrewed previously.
    • With a solid and thin object, unclipse the keyboard by pushing it through the holes you have unscrewed previously.
  3. With an appropriate tool,  carefully remove the blue connector. With an appropriate tool, carefully remove the orange connector. With an appropriate tool, carefully remove the orange connector.
    • With an appropriate tool, carefully remove the blue connector.
    • With an appropriate tool, carefully remove the orange connector.
Conclusie
To reassemble your device, follow the steps in reverse.
Met dank aan deze vertalers:
100%
Lorenzo helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Felice Suglia
21.404 Reputatie
183 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 138
