Inleiding
If the camera is not working correctly follow this guide to replace it.
Wat je nodig hebt
Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
Use the slim plastic opening tool to pry the camera from its initial position.
Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
Bijna klaar!
Conclusie
