Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
Insert the flat side of the tire lever between the inside edge of the rim and the seal of the tire.
Clip the tire lever to the nearest spoke.
Insert the second tire lever next to first and slowly slide it along the outside edge of the rim until one side of the tire is off the rim.
Re-insert the first tire lever to hook the opposite seam of the tire and repeat steps 3 through 5.
Remove the cap from the inner tube, and pull the valve stem out of the rim.
4 andere personen hebben deze handleiding voltooid.
