Ga door naar hoofdinhoud
Mt. Fury Roadmaster Pedal Replacement
Wat je nodig hebt
  1. Mt. Fury Roadmaster Pedal Replacement, Pedal: stap 1, afbeelding 1 van 1
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  2. Mt. Fury Roadmaster Pedal Replacement: stap 2, afbeelding 1 van 3 Mt. Fury Roadmaster Pedal Replacement: stap 2, afbeelding 2 van 3 Mt. Fury Roadmaster Pedal Replacement: stap 2, afbeelding 3 van 3
    • Locate the 15mm pedal nut, and position the crank arms for maximum leverage.
    • Using a 15mm open-end wrench, brace the opposite pedal with your other hand and remove the pedal nut from the crank arm.
    • A considerable amount of force may be required to break pedal nut free.
Conclusie
To install new pedal, follow these instructions in reverse order.
Samantha Rawlins
476 Reputatie
3 handleidingen geschreven
Cal Poly, Team 1-40, Maness Winter 2014 Lid van Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 14
Altijd: 2,399
