Ga door naar hoofdinhoud
Mr. Coffee DW13 Power Cord Replacement
Wat je nodig hebt
  1. Mr. Coffee DW13 Power Cord Replacement, Base: stap 1, afbeelding 1 van 2 Mr. Coffee DW13 Power Cord Replacement, Base: stap 1, afbeelding 2 van 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Power Cord Replacement: stap 2, afbeelding 1 van 2 Mr. Coffee DW13 Power Cord Replacement: stap 2, afbeelding 2 van 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Power Cord Replacement: stap 3, afbeelding 1 van 1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 Power Cord Replacement, Power Cord: stap 4, afbeelding 1 van 2 Mr. Coffee DW13 Power Cord Replacement, Power Cord: stap 4, afbeelding 2 van 2
    • Locate the white tab that covers and holds the power cord in place. It has two screws on either side of it.
    • Use a #2 Philips Head screwdriver to unscrew the two 13mm screws holding the tab in place.
  5. Mr. Coffee DW13 Power Cord Replacement: stap 5, afbeelding 1 van 2 Mr. Coffee DW13 Power Cord Replacement: stap 5, afbeelding 2 van 2
    • Gently lift up on the white tab, removing it from the coffee machine.
  6. Mr. Coffee DW13 Power Cord Replacement: stap 6, afbeelding 1 van 2 Mr. Coffee DW13 Power Cord Replacement: stap 6, afbeelding 2 van 2
    • Locate the 2 electrical connectors running from the black plastic-coated power cord to the interior of the power switch.
    • One cord is copper colored and ends at the power switch in a silver metal square.
    • The other cord is white and ends at the power switch in a black plastic square.
  7. Mr. Coffee DW13 Power Cord Replacement: stap 7, afbeelding 1 van 2 Mr. Coffee DW13 Power Cord Replacement: stap 7, afbeelding 2 van 2
    • Grasp the copper cord close to the power switch. Lightly pull the silver end tab from the end to detach it.
  8. Mr. Coffee DW13 Power Cord Replacement: stap 8, afbeelding 1 van 2 Mr. Coffee DW13 Power Cord Replacement: stap 8, afbeelding 2 van 2
    • Lightly pull the white cord away from the power switch by grasping the black plastic-coated head.
    • There are two white cords attached to each other. Pull them apart by grasping the different black heads and separating them.
  9. Mr. Coffee DW13 Power Cord Replacement: stap 9, afbeelding 1 van 3 Mr. Coffee DW13 Power Cord Replacement: stap 9, afbeelding 2 van 3 Mr. Coffee DW13 Power Cord Replacement: stap 9, afbeelding 3 van 3
    • Pull the power cord through the hole at the back of the base of the machine, followed by the two colored cords.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Tess Bradley
373 Reputatie
3 handleidingen geschreven
Cal Poly, Team 10-31, Maness Winter 2014 Lid van Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 21
Altijd: 3,219
