Inleiding
This is an easy replacement. All you need to do is open the top of the coffeemaker, move a black plastic arm, and lift the filter out of the machine.
  1. Face the top of the coffeemaker towards you.
    • Face the top of the coffeemaker towards you.
  2. Identify the two tabs on top of the machine. Lift the top of the coffeemaker up, using these tabs
    • Identify the two tabs on top of the machine.
    • Lift the top of the coffeemaker up, using these tabs
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Slide the black spout towards the back of the coffee maker, exposing the filter. Slide the black spout towards the back of the coffee maker, exposing the filter. Slide the black spout towards the back of the coffee maker, exposing the filter.
    • Slide the black spout towards the back of the coffee maker, exposing the filter.
  5. Using the side tabs, gently lift the filter up and out of the machine. Using the side tabs, gently lift the filter up and out of the machine.
    • Using the side tabs, gently lift the filter up and out of the machine.
Conclusie
Tess Bradley
343 Reputatie
3 handleidingen geschreven
Cal Poly, Team 10-31, Maness Winter 2014 Lid van Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 6
Altijd: 418
