Inleiding
In order to remove the base of your Mr. Coffee DW13, you will need to position the coffee machine so that the bottom is facing you. After, you will remove eight screws and gently lift the cover from the base.
Wat je nodig hebt
Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
Één andere persoon heeft deze handleiding voltooid.
