Inleiding
This replacement guide would be useful if your Mr. Coffee BVMC-SJX33GT has a broken or cracked base. It also serves to demonstrate how to get into your coffee maker in order to make other repairs.
Make sure your coffee maker is unplugged and empty of all water before attempting to make any repairs.
Wat je nodig hebt
Also the front two screws are safety screws: they have a 6 sided star shape with a raised dimple in the center to prevent homebodies from casually opening the machine. (probably from the Sunbeam’s (owns Mr. Coffee) legal dept.) Anyway you will need a security bit to remove the screws and not a phillips screw driver.
3 andere personen hebben deze handleiding voltooid.
Één opmerking
Hi Mackenzie, I'm trying to take off the base of my Mr. Coffee coffeemaker (ISX23GTF). I've found six screws, four were easily removed with Philips screwdriver, but two have star-shaped torx style heads (not certain what they are called). I have three different torx sets, none of which seems to work. The only thing I can think off is trying to drill out the screw, but I am worried about damaging the unit. Any suggestions?
