Ga door naar hoofdinhoud
Mpow MPBH063 Daughterboard Replacement
Wat je nodig hebt
  1. Mpow MPBH063 Daughterboard Replacement, Daughterboard: stap 1, afbeelding 1 van 1
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
  2. Mpow MPBH063 Daughterboard Replacement: stap 2, afbeelding 1 van 1
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
  3. Mpow MPBH063 Daughterboard Replacement: stap 3, afbeelding 1 van 1
    • Unplug the wire connected to the daughterboard.
  4. Mpow MPBH063 Daughterboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the silver 10 mm screw from the center of the daughterboard.
  5. Mpow MPBH063 Daughterboard Replacement: stap 5, afbeelding 1 van 2 Mpow MPBH063 Daughterboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the daughterboard by carefully lifting the daughterboard out of the speaker with the metal spudger.
    • Use iFixit adhesive remover as directed
    • Before you remove the daughterboard, cut around the edges using the tech knife, and remove the adhesive securing the daughterboard to the speaker.
Conclusie
Jazely Barrera
121 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 143
