Ga door naar hoofdinhoud
Mpow MPBH063 Battery Replacement
Wat je nodig hebt
  1. Mpow MPBH063 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Mpow MPBH063 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Mpow MPBH063 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
  2. Mpow MPBH063 Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
  3. Mpow MPBH063 Battery Replacement: stap 3, afbeelding 1 van 1
    • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
    • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
    • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
  4. Mpow MPBH063 Battery Replacement: stap 4, afbeelding 1 van 1
    • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
Conclusie
To insert a new replacement battery and reassemble your device, follow these instructions in reverse order.
Lianna Cook
248 Reputatie
2 handleidingen geschreven
2 opmerkingen
Where can I find a replacement battery for this speaker?
Sean DuBois - Antwoord
I’ve owned this speaker for ages and have never been able to use it to charge anything. Can someone tell me what sequence of button I have to press to get it to work as a power bank?
RJ En - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 4,278
