Ga door naar hoofdinhoud
Mpow 059 Ear Cushion Replacement
Wat je nodig hebt
  1. Mpow 059 Ear Cushion Replacement, Ear Cushion: stap 1, afbeelding 1 van 2 Mpow 059 Ear Cushion Replacement, Ear Cushion: stap 1, afbeelding 2 van 2
    • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
    • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
    • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
    • Applying too much pressure can damage ear cushion.
  2. Mpow 059 Ear Cushion Replacement: stap 2, afbeelding 1 van 1
    • Remove the ear cushion away from the speaker to completely detach it from the headphones.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Danielle Furtado
490 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team E-1, Gurgel Spring 2022 Lid van UMass Dartmouth, Team E-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SEG1
3 Leden
4 handleidingen geschreven
8 opmerkingen
Really amazing
hopeful Hr - Antwoord
thank you. very helpfule.
P Gill - Antwoord
These instructions do not mention anything about the fact that you need a new adhesive to make the new earpads stay. Now I won't have headphones until I'm able to purchase an adhesive.
Cody Owens - Antwoord
Is there a recommendation on the replacement ear pads?
Some say glue is needed but does this depend on the replacement pads?
ms13sp - Antwoord
Works great. I have replaced my earpads 3 times with no glue. I use these MOKOS earpads from amazon. Replacement earpads for Mpow 059
Thanks for the step by step guide. I love these Mpow headphones, mostly for the controls on the right ear.
anotherdee - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 174
Altijd: 6,152
