Ga door naar hoofdinhoud
Mountain Bike Brake Lever Replacement
Wat je nodig hebt
  1. Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: stap 1, afbeelding 1 van 2 Mountain Bike Brake Lever Replacement, Mountain Bike Brake Lever: stap 1, afbeelding 2 van 2
    • Remove the grip from the handle.
    • Do this by twisting and pulling the grip until it slides off.
  2. Mountain Bike Brake Lever Replacement: stap 2, afbeelding 1 van 2 Mountain Bike Brake Lever Replacement: stap 2, afbeelding 2 van 2
    • Using a 5mm allen key, loosen the lever assembly from the handle.
    • Slide the assembly off of the handle.
  3. Mountain Bike Brake Lever Replacement: stap 3, afbeelding 1 van 1
    • Take your new lever assembly and slide it onto the handle; leave it loose.
  4. Mountain Bike Brake Lever Replacement: stap 4, afbeelding 1 van 2 Mountain Bike Brake Lever Replacement: stap 4, afbeelding 2 van 2
    • Pour a light amount of isopropyl alcohol through your grip and slide it back onto the handle.
  5. Mountain Bike Brake Lever Replacement: stap 5, afbeelding 1 van 1
    • Line up your lever assembly back into place.
    • Tighten the screw with the allen key to secure it.
  6. Mountain Bike Brake Lever Replacement: stap 6, afbeelding 1 van 3 Mountain Bike Brake Lever Replacement: stap 6, afbeelding 2 van 3 Mountain Bike Brake Lever Replacement: stap 6, afbeelding 3 van 3
    • Install the brake cable into the lever housing.
    • Take the brake cable and feed it into the lever pull.
  7. Mountain Bike Brake Lever Replacement: stap 7, afbeelding 1 van 3 Mountain Bike Brake Lever Replacement: stap 7, afbeelding 2 van 3 Mountain Bike Brake Lever Replacement: stap 7, afbeelding 3 van 3
    • Feed the cable into the lever assembly slot and through the barrel adjuster.
    • Use the barrel adjuster to tighten the cable intro place.
Conclusie
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 97
Altijd: 3,418
