Inleiding
This guide is for those looking to replace their brake lever assembly on a mountain bike. It is a fairly simple task that does not require much prior bike knowledge. It only requires a 5mm Allen key, the lever assembly, isopropyl alcohol, and the bike.
Wat je nodig hebt
Now your lever assembly should be properly hooked up and ready to function! Giving the lever a couple test pulls to make sure it is applying brake pressure is recommended.
Één andere persoon heeft deze handleiding voltooid.
