Inleiding
Before proceeding with the replacement guide, make sure the headphones are unplugged from any device.
Wat je nodig hebt
Remove star head screw from above base of the microphone with T6 Torx Screwdriver.
To prevent stripping, use an appropriate bit and ensure screwdriver is oriented perpendicular to the face of the screw.
Clip both wires to remove defective microphone.
Be sure to clip as close to the base of the microphone as possible in order to have enough wire for the new microphone.
Align wires with corresponding pads on new microphone and solder in place.
For soldering, see the Ifixit soldering guide: Hoe moet je (de-)solderen?
Één andere persoon heeft deze handleiding voltooid.
