Ga door naar hoofdinhoud
Motorola i850 Speaker Replacement
Wat je nodig hebt
  1. Motorola i850 Speaker Replacement, LCD Board: stap 1, afbeelding 1 van 1
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Motorola i850 Speaker Replacement: stap 2, afbeelding 1 van 2 Motorola i850 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
  3. Motorola i850 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the screws using a Phillips #00 Screwdriver.
  4. Motorola i850 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
  5. Motorola i850 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
  6. Motorola i850 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Partially close the flip cover of the phone in order to take off the outer case.
  7. Motorola i850 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Completely remove the outer casing from the phone.
  8. Motorola i850 Speaker Replacement: stap 8, afbeelding 1 van 2 Motorola i850 Speaker Replacement: stap 8, afbeelding 2 van 2
    • Place your thumb underneath the protective metal covering to remove it from the phone.
  9. Motorola i850 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Gently detach the black microchip from the phone with a Tweezer.
  10. Motorola i850 Speaker Replacement: stap 10, afbeelding 1 van 1
    • Prop out the LCD board from the phone using your fingertips.
  11. Motorola i850 Speaker Replacement: stap 11, afbeelding 1 van 2 Motorola i850 Speaker Replacement: stap 11, afbeelding 2 van 2
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
  12. Motorola i850 Speaker Replacement, Speaker: stap 12, afbeelding 1 van 1
    • Use a flathead screwdriver to gently remove the speaker.
  13. Motorola i850 Speaker Replacement: stap 13, afbeelding 1 van 1
    • Insert the new speaker into the phone and it should look like the image at left.
Conclusie
Kevin Dermody
1 Reputatie
1 Handleiding geschreven
Cal Poly, Team 34-56, Forte Spring 2010 Lid van Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,162
