Ga door naar hoofdinhoud
Motorola i710 Keypad Sensor Replacement
  1. Motorola i710 Keypad Sensor Replacement, Battery Cover: stap 1, afbeelding 1 van 2 Motorola i710 Keypad Sensor Replacement, Battery Cover: stap 1, afbeelding 2 van 2
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
  2. Motorola i710 Keypad Sensor Replacement, Battery: stap 2, afbeelding 1 van 1
    • Push the battery towards the top of the phone and lift up.
  3. Motorola i710 Keypad Sensor Replacement, Motherboard: stap 3, afbeelding 1 van 3 Motorola i710 Keypad Sensor Replacement, Motherboard: stap 3, afbeelding 2 van 3 Motorola i710 Keypad Sensor Replacement, Motherboard: stap 3, afbeelding 3 van 3
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
  4. Motorola i710 Keypad Sensor Replacement, Keypad Sensor: stap 4, afbeelding 1 van 2 Motorola i710 Keypad Sensor Replacement, Keypad Sensor: stap 4, afbeelding 2 van 2
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
Conclusie
Katelyn
1 Reputatie
2 handleidingen geschreven
Clemson, Team 14-2, Benson Fall 2012 Lid van Clemson, Team 14-2, Benson Fall 2012
CLEM-BENSON-F12S14G2
4 Leden
17 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 317
